Home Community Uploads
Cireson Partners, Customers and Community members share your customizations and examples here to help benefit the community as a whole to earn Kudos and badges.
DISCLAIMER
All files and projects located here are provided and come "as-is" and without any warranty or support. Use at your own risk. Your use of Community Uploads is subject to our Terms of Use.
Cireson does not and will not support or maintain these enhancements, extensions, and scripts.
For Team Cireson uploads click here.
Request Offerings and pasting Images - possible Solution
Roland_KindRoland_Kind Partner Advanced IT Monkey ✭✭✭
Hello,
based on the idea of @John_doyle --> https://community.cireson.com/discussion/2595/transforming-the-grid-picker/p1
I have created a small script to enable pasting of Images inside the request offerings and converting them to attachments.
Use a RO configuration like this (please note: the field following the @Editor tag, will be used to store the text - this field should be used for mappings)
Mapping example:
This will give you a RO shown here:
The Images which are pasted to the text area, are converted to an attachment and will be added to the RO - to preserve the info, where the Image was located within the text, a reference is added to the text (e.g. image1.png) . The saved IR looks like this:
Please note:
this was just tested with IE/Edge but no other browsers in a Windows10 test environment / latest 2016 version of the Portal 8.2.x
to test/use this, just add the contents of the zip file to your custom.js :-)
