New SCOM Management Pack for monitoring Cireson Portal and Cache Builder
Hi
I thought i would post in here to let people know that I've built a SCOM management pack which provides discovery and monitoring for all the key supporting components of Cireson Portal instances including:
All server roles:
  • Cireson Portal Web Servers
  • Cache Builder Servers
  • SQL Servers hosting the Cache Builder ‘ServiceManagement’ database
All application components:
  • Cireson Portal IIS Website instances and Application Pools
  • Cache Builder Windows Service instances
  • Cache Builder ‘ServiceManagement’ SQL database Instances
This Management pack has no server specific dependencies like WMI compatibility etc, and can also cater for non standard install routines of the Portal instance(s) for example, has been installed in a non default file / folder path and / or the website has been named something different from the default CiresonPortal.
The Management Pack is compatible with SCOM 2012 R2 and 2016. There are plenty of other elements included, so please take look here- https://gallery.technet.microsoft.com/Cireson-Portal-Cache-d6206955  ...any feedback would be much appreciated.
Thanks!
1
