API Calls do not work for Asset management
Hello guys,
I recently built a Hardware Asset management for end users for our productive system, which is built up on Javascript and Cireson API Calls - Portal Version 9.4.5.2016. Everything is working fine here.
I also tried to implement it in our new poroductive system, which we build up currently. This is Portal Version 11.2.2.2016. With the new version I have a problem with the API calls. When I use the GetProjectionByCriteria POST call, I always receive an empty array if I use a Type Projection which has an Asset Management Class as Source, even when built in. I tried with built in SCSM Type Projections for classes like Domain User and Computer, and it is working fine here - I receive back the object JSON.
I have installed the program Postman for testing and it is the exact same situation. Are there any settings I need to set, so I can access Cireson Assets via API? Or is this a Bug in the new version?
1 reply
