Powershell
Hello!
I am creating several powershell scripts that draw on MAs under PAs or a Powershell script that can get affected user from the parent SR.
However My titles do not seem to update and my emails may or may not send depending on how deep it goes.
My scripts are attached - but my question is: How do I get the parent SR from deep under a PA? Also, How do retrieve MAs under a PA? I am using PowerShell
ACs and storing the PowerShell as templates in scsm.
Might be a bit so I highly appreciate any help!
Thanks!
