Use MP Enumeration List item as criteria for Query Results Prompt
I have created a custom list to hold over 200 types of "departments". I would like the user to be able to select a department from the list and have the selected department drive the criteria for the next query results field. This will be helpful because our company has 40,000 users and I cannot display all of them in the query results so I would like to use the enumeration list item to filter the query results. You can accomplish this with a simple list but that is not a good option because of the amount of list items. You would have to type 200 list items into each RO you wanted to use the list in.
So to sum up I would like to use the enumeration list result to set criteria for the department property of the active directory users class.
I have included some screenshots to show how the enumeration list does not show available criteria.
