Ability to put portal offline (for maintenance)
It would be great to be able to put the portal offline with to everybody other than administrators.
Enable maintenance during business hours.
I had an situation were a key runbook was accidently deleted form Orch and I had to recreate and test, but users were still using the portal and bugging me about problems which extended out the time to fix and increase stress levels.
If I could have put it offline for a few hours I would have got the fix done quicker.
Create another web site (remember to use the same bindings if you do any https redirection) at the same level as your portal, which will be stopped during normal operation. If it is set up correctly, you should get an error ("This website cannot be started. Another website may be using the same port.") any time you try to start it, if your CiresonPortal site is still running.
The other web site can have a static HTML file, such as a text notice about the planned outage--whatever you like. If you want to really take good care of your users, you can add rules to this site that redirect/rewrite all URLs within it back to your static page (e.g., https://yoursite/Incident/Edit/IR1234 gets sent to https://yoursite/message.html).
When you want to put your site in maintenance mode:
- Change the ports to CiresonPortal to something different, such as 81/444 (external traffic into to these ports is probably disallowed in most externally-facing implementations, but that is not necessarily a problem in this scenario)
- Start your "other" web site (which will begin accepting traffic at ports 80/443)
Now they are both running, but your users will just get a message about the downtime, because they are not specifying the alternate ports. Reverse these steps to set things back to normal.Caveats:
We have just migrated from SCSM2012 to SCSM2016 and latest Cireson portal version using the Cireson LM app. We also changed our website address to something more meaningful. I had to enabled the HTTP redirect so that anyone that had a link to the old url address would be redirected to the new address. What I am trying to do now is enable a non redirect for the old link for our analysts to check the old tickets (Closed / Resolved as we did not bring these across.) I noticed the Webconfig file has a redirect setting in it.
I was wondering if there is a way to add code to say that if you are using Firefox or Chrome to not redirect but use the old site address so that analysts could look at the old data? Below is the extract from Webconfig file. I would like to redirect to http://xyz.com for the analysts. Is this possible?
