Print output?
Tony_Collett Cireson Support Super IT Monkey ✭✭✭✭✭The Print task on the Portal is simply a shortcut to Ctrl+P or File>Print... which is default in the browser.
While there's no option to automatically expand the description, you could log a Feature Request for a 'Clean Print' option, which provides a better formatted print page which looks better on paper.6
