Home Service Manager Portal Feature Requests
We appreciate you taking the time to vote and add your suggestions to make our products awesome! Your request will be submitted to the community for review and inclusion into the backlog.
Create Problem and Create Change tasks on work item forms
Leigh_KildayLeigh_Kilday Member Ninja IT Monkey ✭✭✭✭
The SCSM console has these tasks already, but the portal does not. The task copies key information from the initial WI to the new one and automatically creates a relationship.
I'd like to see 'Create Problem' on the Incident form, and 'Create Change' on Incident and Problem forms.
There are probably others that would make sense (like Create Release), but these are the two that our users are desperate for.
Somebody has already mentioned selecting multiple WIs in tabular views to create PRs, so this functionality would accompany that nicely.
8 votes
Submitted · Last Updated
  • Geoff_RossGeoff_Ross Cireson Consultant O.G.
    Hi Leigh,
    Would the following unsupported solution help you?
    https://community.cireson.com/discussion/63/convert-ir-to-pr#latest
    Its a custom task written by the services team.
  • Leigh_KildayLeigh_Kilday Member Ninja IT Monkey ✭✭✭✭
    Hi Geoff,
    It looks like it'll do the trick for now. I'd still like for the solution to be supported in the base portal installation in the future. We have a bunch of workarounds to fill the gaps in SCSM and it can be cumbersome to manage all of the components between class extensions, custom workflows, runbooks, PowerShell scripts and CustomSpace files.
    Thanks!
  • Martyn_FearnMartyn_Fearn Customer Adept IT Monkey ✭✭
    We're getting ready to go live with the Change module in SCSM so we'd very much like to see this added.
