Help with Setting up Notification when comment added
Dear All,
I need some direction on setting up notifications when new comments are added to incidents, and how best to do this in SCSM.
Kind Regards
Daniel
CaterhamITSupport Member Advanced IT Monkey ✭✭✭
Hi Shane,
I managed to get this working with end.
Thanks for the help.
Daniel
0
Hi @CaterhamITSupport
The easiest way to do this for comments on an incident is using the pro version of Notify Analyst which gives access to this:
Thanks,
Shane
I would prefer to do this with SCSM though. Can you advise?
Daniel
You cannot do this out of the box in SCSM, so it would require custom work in SCSM.
Thanks,
Shane
Hi Shane,
Daniel
