SCSM SSRS - SQL Help - Affected User / Assigned User - Please help
Dear All,
I am having issues with getting reports with affected user and assigned to user. I have the following code and when I add the deleted date part into the where part it doesn't show all the incidents..
AND (wiau.DeletedDate is null)
AND (wiat.DeletedDate is null)
When i remove them it shows me duplicates with other people assigned in the past, can anyone help me with this. Its not giving me the correct results and I'm struggling with this one.
Thanks
Daniel
LEFT OUTER JOIN entitydim as e on IncidentDim.EntityDimKey = e.EntityDimKey
LEFT OUTER JOIN workitemdim as wi on e.EntityDimKey = wi.EntityDimKey
LEFT OUTER JOIN workitemaffecteduserfactvw as wiau on wi.WorkItemDimKey = wiau.WorkItemDimKey
LEFT OUTER JOIN UserDim as affectedUser on wiau.WorkItemAffectedUser_UserDimKey = affectedUser.UserDimKey
LEFT OUTER JOIN WorkItemAssignedToUserFactvw as wiat on wi.WorkItemDimKey = wiat.WorkItemDimKey
LEFT OUTER JOIN UserDim as AssignedToUser on wiat.WorkItemAssignedToUser_UserDimKey = AssignedToUser.UserDimKey
WHERE
ORDER BY IncidentDim.CreatedDate DESC
CaterhamITSupport Member IT Monkey ✭
I managed to fix this by changing to by moving the where statement part to the joins:
AND wiau.DeletedDate is null
AND wiat.DeletedDate IS NULL
0
Found here:
https://community.cireson.com/discussion/475/query-pulling-first-assigned-to-and-not-the-current-assigned-to-suggestions
