Home General Discussion
Cireson Portal - Code help
CaterhamITSupportCaterhamITSupport Member Advanced IT Monkey ✭✭✭
edited May 16 in General Discussion
Dear All,
Is there a way to change the status on portal if the assigned person is equal to a person.
I know that you can do this in the console but have a issue with this at the moment for an individual.
If you have some code which can do or help with:
If assigned to equals x person then change status to something
Kind Regards
Daniel
  • Brad_ZimaBrad_Zima Member Advanced IT Monkey ✭✭✭
    Daniel,
    For something like this you would probably want to use an Orchestrator runbook with a monitor activity.
    Something along the lines of:
    Monitor Incidents for updates,
    Get related objects equal to AssignedToUser,
    If user equals {user you're trying to look for},
    Update work item Status field to desired status.
