Offerings not showing for Portal Users
I am using Cireson Portal Community edition v6.0.0.5. All Service and Request Offerings are showing in Sliverlight Portal however in Cireson Portal, end users cannot see any of them.
Is there any configuration required for the Portal Users in order to see the offerings?
Best Answers
Joe_Burrows Cireson Devops Super IT Monkey ✭✭✭✭✭Id recommend checking the cachebuilder.log file to make sure there is no errors that indicate syncing failed.
Also check your have created an end user role and targeted a domain user group (as the cireson portal does not work with the default authenticated users)5 -
Geoff_Ross Cireson Consultant O.G.Hi Ozge,
The problem with using domain users in that most people don't think to import this group into service manager and therefore it doesn't get pushed into the portal DB by the cachebuilder. It gets missed in SCSM as its in the built in AD container not in your groups OU (at least by default).
If you want to use domain users, just create another AD connector targeted at this group only, let it run once and then you can leave it disabled.
As for the different offerings you are experiencing this is due to different behaviour in the MS Silverlight portal and the Cireson portal. Permissions in Cireson portal are only done at the Service Offering level, not down to individual ROs.
There is a feature request to change this so I recommend you up vote it if you need more granular permissions.
Geoff
6
Geoff
