Portal installation successful but web page format not correct
Hi,
Installed the Cireson Portal which says a successful install. When I open the portal, it just displays as a series of links and plain text down the left hand side. Only message in the log is
"Failed to add windows service event sources: Source WebAPI already exists on local computer" and " Failed to add windows service event sources: Source WebPortal already exists on local computer".
Uninstalled everything and tried again on a different server. Same result. I'm sure this is IIS related but can't put my finger on it. Anyone seen this before?
Cheers
Steve
OptionsSteve_Barnard Partner IT Monkey ✭The portal installation failed to install all the correct IIS features. Nothing was displayed in the log file however. After backing up IIS on the problem site and comparing to a working site, I just added the same features which resolved the issue.6
