Problems after Updating to Cireson Advanced Send Email 2.2.2016.1
Hello folks,
i have recently updated the Cireson Advanced Send Email to Version 2.2.2016.1 and now I have got some issues.
The field CC fills the following thing before the regular Email Address:
;sip:example@example-email.com
and when I format the Text in the body, I can’t undo the underline option, it stayes underlined for ever. Bold and italic can be undo.
Has anybody got the same issues?
Regards
Oliver
Matt_Medley Member Advanced IT Monkey ✭✭✭Hey guys, while working with another customer on this issue, I think I've discovered the issue. Can someone with this issue check a users exchange properties and see if their SIP email address is listed / selected as their primary address? If so, please change it to their SMTP address as their primary and test again.5
Unfortunately I do not have access to version 2.2.2016.1
However in the general settings is there a prefix the CC field option, this may be prepopulated with the email address.
I know you could prefix the subject line in version 2.0.0.9
Hi
just checked the knowledge base on Cireson support portal.
This is the result:
Advanced Send Email Release Notes
v2.2.x.1
we have exact the same issue. Too much semicolons and sometimes also the SIP address is used.
Are there any known tipps?
https://support.cireson.com/Problem/Edit/PR70465/
I would consider the upgrade as a success though, just need some fixes for this particular App.
Our team would really like to turn off the CC auto-fill feature. Does anyone know of any way to do this? We must delete the auto-filled email addresses and semicolons each time we send an email from Service Manager Incidents. We just upgraded to SM 2016 and to the newest Advanced Send Email.
