Remote Manage - Disable Remote PowerShell Prompt
Howdie All,
Touching base to see if there is anyway for us to disable the ability for our users to use the PowerShell button under Tools on the Other tab.
We want to remove the ability for our users to click the button and be presented with the remote command prompt.
If there is anything that I am missing to restrict/prevent this, please advise.
Thanks!
F_Christiansen Cireson Dev Advanced IT Monkey ✭✭✭
Hi Brad,
Sorry, currently we cannot disable or hide the PowerShell button.
You can add this as a feature request though as I agree it would be a good idea to b able to do so.
Best regards
Flemming Appelon Christiansen5
Best regards
Appreciate the quick response
