Managing Hardware Assets in Portal with their extensions
Because of a memory issue with the SCSM console, we'd like to use the portal to manage our hardware assets. Unfortunately, I've found a couple of limits that do not allow proper handling of the assets in the portal.
1. we use an extension tab on the hardware asset form to add information like replacement year, pin and puk for smartphones or IP addresses for printers. These extensions are not displayed in the hardware asset form in the portal. How would I be able to edit them without using the console?
2. opening All Hardware Assets in the portal does not allow for a search using the asset's name. We have more than 6500 hardware assets. How do I find a specific asset without either having to group by type or add additional views to better find an asset? Any possibility for filtering like in the console?
3. we have console tasks to be executed for specific assets, like printing a sticker with the serial number and MAC. Is there a change to add these tasks to the portal to be executed there?
We use the portal for SCSM version 2012 R2. Thanks for your advice.
Ingrid
Michael_Aidinovich Cireson Solution Architect Advanced IT Monkey ✭✭✭
Hello Ingrid,
Lots of questions, so we'll start at the top
1. Regarding Asset Extensions on the Portal - With the introduction of the Cireson Platform released in Portal V8 it is possible to create a custom Portal HW Form using your customized fields from the AM extensions tab leveraging the Platform/HW/API's. The recorded webinar may be of help
2. Searching HW assets. With Portal V8, searching and filtering HW assets among other asset data is now out of box. Again you can always create a custom HW asset form if needed.
3. From my understanding with Portal V8, Yes, you can add task for Assets.
Hope that helps,
Mike5
Hope that helps,
Mike
Hello Michael,
I haven't looked into the new features of the V8 portal. I'll check it out and will plan the update. Right now, we're running on V7.4. Thanks.
Ingrid
