Special Permission need for CreateOnBehalfGroup ? Translation-Issues in Portal with German Language
(Sorry for my english)
We are using the CreateOnBehalfGroup-Function allow users to create tickets for other users.
We create an AD-Group "SCSM-Portal-User" (Memder is the AD-Group "Domain-User") for the CreateOnBehalfGroup-Function. In the Portal-Configuration we add Group "SCSM-Portal-User" to the CreateOnBehalfGroup-Section. So far, so good.
When "normal" User use the CreateOnBehalf-Function and make a query to find a User, the result every time is empty.
When an Admin-User does makes the same, the result is fine:
Are there any special permission we have to set vor the CreateOnBehalfGroup-AD-Group? I can`t find anything
And we have some Language Translation issues. There are some parts in the Webportal, where all fist Letters are capital, like in the ScreenShot:
We have checked the Translation in the Portalconfig, all ist fine. I think thats a Bug in the HTML-Code?
And is it possible to set the start-size from the Query-Dialog and the query result Limit?
Thanks for any Response
Regards from Germany
Stefan
Hi,
regarding you second topic "capitalize all first lettters" --> add this to your custom.css - that should work
label {
text-transform: none;
regards
Hi Roland,
thanks for the quick Response.
Unfortunately, it doesnt work
. Have also restart the Server.
Regards
Stefan
Hi Stefan,
thats strange - just to be sure, did you empty your local browser Cache (temporary files etc. ?)
(the "old" custom.css is maybe cached on your pc)
regards
Roland
have cleared and empty anything. (Browsercache / Tempfiles) Nothing changed.
Have tested this on different Clients. Same result.
May be Cireson Support has an Idea
RegardsStefan
Hi Stefan,
thats really strange - because in my env. it looks like this:
If I remove the lines from the custom.css it looks like your screen shot - I am using Portal 8.2.x / 2016
I am not sure, but did you customize the request offering (yes/no question)
regards
Roland
yes, we have customized the custom.js and add some Code for the Checkboxex.
Found this here in the Community
I try it with an empty custom.js.
(Update:)
With empty custom.js. it Works
Thank you very much for your Support
Regards
Stefan
Hi Stefan,
great :-) - maybe your customization can be adopted to work with this, too,
(maybe a css (inline) style is missing)
regards
Roland
