Run parts of PS-Script as other user
Hi,
we have a workflow-user who has no permissions for the Active Directory and is only used to run workflows within SCSM. For AD actions we have an ad-connector-user. My goal is to run PS-Scripts executed by the workflow-user and perform some AD actions within the script as the ad-connector-user.
I performed following steps on my SCSM machine:
- logged on as workflow-user
- saved the ad-connector-user credentials with "cmdkey" in the credential manager
- successfully executed a test script as workflow-user with following lines included:
$cred = Get-StoredCredential -Target ad-connector-user | ConvertTo-SecureString
Invoke-Command -Computer scsm-machine -Credential $cred -Authentication CredSSP -ScriptBlock $script -ArgumentList $user_name, $printer_Name
We integrated the PS-Script within an Service Request but there are problems with the "Credential" Parameter (see attached file). Do you have a proper solution to run parts of a script as other user?
Thank you!
Roland_Kind Partner Advanced IT Monkey ✭✭✭
Hi,
just to be sure - you tested the $cred variable when running 'in the' workflow - 'not' as an interactive user ?
at your second questionyes, it is possible without a password in cleartext ... I use the following approach:
## how to convert password strings to secure string and create encrypted string from secure string
## $key= (63,54,132,223,56,24,124,22,123,176,232,23,22,14,133,33,21,134,22,47,96,15,35,13)
## $sc=ConvertTo-SecureString 'passwordstring' -AsPlainText -Force
## $st=ConvertFrom-SecureString -SecureString $sc -Key $key
##the $st / $secString var should then be used in your script like :
$secString="764YwBkADcANkADMAM .... AA1ADMANwBkAGEANgBjAIAZgA1AGQANgA2AGUAMQA="
$password = ConvertTo-SecureString -String $secString -key $key
$username = "domain\user"
$un = New-Object System.Management.Automation.PSCredential($username,$password)but please note - in both methods yours (cred store) and the above method the pw is not 100% safe ...
regards
2
Hi just a quick thought.... did you run your test on the scsm workflow Server - or on your local machine ?
so maybe the credentials are not available on the workflow Server
Hi Roland,
I successfully ran the test on our scsm-workflow-server logged on as the workflow-user. That´s why this problem gives me headache
I tested following on the SCSM-workflow-machine logged on as workflow-user:
Write-Output $credOutput from Windows PowerShell ISE: System.Management.Automation.PSCredential
Output from PoweShell Activity within a Service Request in Service Manager Console: <nothing>
This is driving me crazy because both tests are made on the same machine with the same user. But thank you for that hint Roland!
Is there any other way to run parts of PS scripts as other user without storing the credentials in cleartext?
Hi,
regards
Yes, I used the $cred variable within a test service request which is executed by the workflow-user.
Thank you very much for this example! Works like a charm!
