We're excited to introduce you to 14 new Remote Support apps as part of the existing Service Management Stream!
These modern, web-based, user and device management tools for Analysts help further maximize productivity, deliver faster problem resolution and increase end user satisfaction.
Check out our on-demand webinar to find out how these new apps fit into your existing Team or Service Management Foundation license, see a technical overview demo, and more.View the installation & setup webinar to learn how to get started with Remote Support.
Remote Management integration with analyst portal - iframe http 500 error
I configured Remote Management app on a test server (all-in: SQL server, SCSM, Analyst Portal). I configured a random port for RM (:90) and I set the link to the RM in the portal Integration Settings. Now, on localhost it works with no issues. When accesing from intranet, it works if I access the Remote Management web service (with all functionalities) but as soon as I access it from portal (iframe) I'm getting an http 500 error which also blocks the session. I restart the browser and stand alone RM works, but iframe again doesn't work. Anyone knows what setting should I do in order to configure correctly?
To resume:
1. I have analyst portal on port 80: http://cdtciresontest
2.On the same server I have RM on port 90: http://cdtciresontest:90
3. I configured the integration settings on analyst portal to http://cdtciresontest:90
4. The RM works correctly when in stand alone (accessing the link from browser http://cdtciresontest:90) but it doesn't work from portal (iframe - error http 500, which blocks also the stand alone until restart)
5. On localhost it works with no issues
Thanks a lot for your help...
Hopefully this helps to augment your question. I unfortunately do not have a solution to offer (yet?).
You will need to make sure your hosts setting includes all the hostnames you will access the server from:
This file is usually located here: C:\CiresonPlatform
Check instructions here for updating the hostnames and bindings in the config file:
https://docs.cireson.com/articles/#!remote-management-installation/how-to-setup-ssl-for-remote-management
If you still get the iframe error despite the hostnames being correct another thing to try would be listening on the same port but a different hostname such as:
Restart your service
Then configure your integration test for http://cdtciresontest/remotemanagement
