Required comment when putting CR to "On hold" or "Cancel" status
Hi.
In SCSM console when you want to put CR On Hold or Cancel status you will be prompt by popup window for required comment
Is there any way to add this on portal? For eg. on change status popup
Geoff_Ross Cireson Consultant Super IT Monkey ✭✭✭✭✭
Hi Zbigniew,
This would be possible but would require a custom task. The closest I can think of to get you started is this.
https://community.cireson.com/discussion/53/resolved-incident#latest
Geoff
5
Hi Zbigniew,
Geoff
Thanks for information.
