Remote Management Tools
Hi Team,
I'm looking at installing the True Control Centre and Remote Management tools on our development envrironment first to do some testing and configure.
Are there any tips or documentation on how to proceed with this?
Regards
There's install instructions for both, if that's what you mean?
Hi @Mina_Saidi
I would recommend not doing True Control Centre, I would recommend Remote Support which is the first link Konstantin.
This is because the other one will be going end of life at some point as Remote Support is newer and replacing it!
Thanks,
Shane
