Is there a good practise how to sync Knowledge articles between SCSM DB and Cireson DB
Hi,
we want to use the Cireson Knowledgebase, but some employees use the articles, create, delete and update them in the SCSM console. Is there a good way to sync both articles bases between Cireson and SCSM Backend?
Shane_White Cireson Support Super IT Monkey ✭✭✭✭✭
Hi @Jan_Schulz
You can use the below powershell script that John Doyle created to achieve this!
To be honest if you solely want to use the Cireson Knowledge Base I would remove people's permission in the Console to created KB's, migrate them all to the Portal once, and then force people to create through the Portal. Will save a lot of time and effort in the meantime!
Thanks,
Shane
5
Hi @Jan_Schulz
Thanks,
Shane
Hi Shane,
thank you for the information :-)
I think this is a good basis to create a whole sync script.
Thanks,
Jan
