Problem with promoted Views
Hi,
i created a View in SCSM concole with combinated class to show my own created SRs and my own created Incidents. The SCSM console show the view correctly. I promoted the view but the Web but the same View in Webportal doesn show anything.
My goal is to display my created Service Requests and Incidents.
I've noticed that the problem started since we switched to Windows Authentication. The view has this xml-code:
<Expression>
<SimpleExpression>
<ValueExpressionLeft>
<GenericProperty Path="$Context/Path[Relationship='Alias_945d98a31ba6484199ba60d8cb584f1e!System.WorkItemCreatedByUser']$">Id</GenericProperty>
</ValueExpressionLeft>
<Operator>Equal</Operator>
<ValueExpressionRight>
<Token>[ME]</Token>
</ValueExpressionRight>
</SimpleExpression>
</Expression>
I found the answer by myself: https://support.cireson.com/KnowledgeBase/View/31#!/
@Adam_Stoppa - As an alternative, you could do a SQL table widget on a dashboard page. There is a token you can use in SQL queries in the portal. I believe this query will get close to what you're after:
SELECT
WorkItemId,
Title,
sds.DisplayString as 'Status',
AffectedUser,
AssignedUser,
ts.DisplayString as 'SupportGroup',
LastModified
FROM WorkItem wi
join DisplayString sds
on sds.ElementID = wi.statusid
and sds.LocaleID = 'enu'
join DisplayString ts
on ts.ElementID = wi.TierId
and ts.LocaleID = 'enu'
where CreatedByUserId = @UserId
and sds.DisplayString not in ('Closed', 'Resolved', 'Completed')
Hi Justin,
can you explain me how i do this SQL table widget on a dashboard page?
Thanks
adam
@Adam_Stoppa - Here's a link to an article on adding a SQL table widget:
You might check out this article too for adding a dashboard page:
