Is there a way to default Portal Announcements to display collapsed?
I am looking for a way to display the announcements as a single bard across the top on the portal that a user can expand, rather than it be expanded and they have to collapse. Is there an easy way to do this?
Justin_Workman Cireson Support Super IT Monkey ✭✭✭✭✭
@Eric_Evans - If you add the following to your custom.js the announcements will always start as "read".
localStorage.setItem("cireson_last_read_announcement",new Date().toISOString());
0
Worked like a charm thank you!
