Manual activity required (with min char's) completion notes
Dear all,
does anybody have a solution for making the MA completion text required with amount of minimum characters?
Because that function is part of the built in Cireson code I don't want to (or can :)) change it directly.
BR, Peter
@Peter_Muttenthaler - This would require some pretty heavy customization. Maybe a custom task that shows up in the parent (or in the context of the MA's task panel, which is a whole other topic) that launches a custom modal window with your length requirement similar to the "Resolve IR" Addin task.
@Justin_Workman: Thank you for your reply!
Does anybody of you already created something similar like that for MA's?
I've configured the Resolve IR task already, so that could be also be my starting point ;)
