We're excited to introduce you to 14 new Remote Support apps as part of the existing Service Management Stream!
These modern, web-based, user and device management tools for Analysts help further maximize productivity, deliver faster problem resolution and increase end user satisfaction.
Check out our on-demand webinar to find out how these new apps fit into your existing Team or Service Management Foundation license, see a technical overview demo, and more.View the installation & setup webinar to learn how to get started with Remote Support.
News problems
News is not displayed. The problem is in the language settings. If you switch the user interface to English, the news is displayed
Apparently the problem is on the Cireson API side. If English is passed in the announcement request to the API, then the corresponding entries are added to the result set:
But in the transmission of the Russian language, entries are not added:
There is clearly something on the side of the API itself. There is a possibility that when saving the news, the English locale is selected. Although in the SQL database in the table [ServiceManagementCireson].[dbo].[Announcement] there is no sign that the record belongs to any particular language.
We cannot change the logic of the API, because it is a private component.
Maybe someone met this problem.
solved the problem through
[email protected]
Thank you.
