SQL - Reporting - Is there a way to capture items under a PA?
![Ryan_Kelley](https://us.v-cdn.net/6026663/uploads/defaultavatar/nUU92XW7CXYP8.jpg)
I am capturing data for our hiring process and we want to know when runbooks run and end ect.
One runbook sits under a PA and I can join tables to see other runbooks but not the one I want.
Example:
SELECT
s.[Title]
,s.WorkItemId
,s.[UserText2_DDCE6D39_0E80_E3CE_3219_0F163D86BAFD] AS 'User'
,CAST(s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C] AS DATE) AS 'Expected Date'
,s.UserText4_F2285595_280B_DD8D_2A25_4C6EBC4A47C1
,s.[Status]
,s.[Priority]
,s.[AssignedUser]
,s.[CreatedByUser]
,s.[AffectedUser]
,s.[Category]
,s.[TierId]
,s.[Tier]
,s.[LastModified]
,s.[Created] AS Created
,CONVERT(DATETIME, DATEADD(HOUR, -5, [Created]), 100) AS 'Created_minus 5 hours'
,s.[SLOStatus]
,s.[PrimaryOwner]
,s.[PrimaryOwnerId]
,s.[SourceId]
,s.[Source]
,s.[ScheduledStartDate]
,s.[ScheduledEndDate]
,s.[ContactMethod]
,s.[Description]
,s.[DisplayName]
,s.[RequiredByDate]
,s.[ResolvedDate]
,s.[ClosedDate]
,s.[CompletedDate]
,s.[ImplementationPlan]
,s.[ImplementationResults]
,s.[Resolution]
,s.[ResolutionCategory]
,s.[ResolutionDescription]
,[Id_9A505725_E2F2_447F_271B_9B9F4F0D190C] AS RunbookID
,CONVERT(DATETIME, DATEADD(HOUR, -4, [ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78]), 100) AS 'Actual_End_Runbook_minus 5 hours'
,ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78] AS Actual_End_Runbook
,DATEDIFF(DAY, s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C], ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78]) AS DateDiffuse
,CONVERT(INT, DATEDIFF(DD, s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C], ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78])) AS datediff_days
,CONVERT(INT, DATEDIFF(HH, s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C], ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78]) % 24) AS datediff_hours
,CONVERT(INT, DATEDIFF(MI, s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C], ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78]) % 60) AS datediff_minutes
,DATEDIFF(MI, s.[UserDate1_8210C35D_BC14_9150_E70D_BCA5EAF37E2C], ra.[ActualEndDate_A3C4A137_3FF8_39E2_BE65_2D070EEA2E78]) AS DateDiffminutestotal
FROM [CiresonAnalytics].[dbo].[SM_WorkItem_ServiceRequest] s
INNER JOIN dbo.SM_WI_Relationship r ON r.SourceEntityId = s.id
JOIN [ServiceManager].[dbo].[MT_Microsoft$SystemCenter$Orchestrator$RunbookAutomationActivity] ra ON ra.BaseManagedEntityId = r.TargetEntityId
WHERE title LIKE '%Provision IT Services for New User%'
AND Created BETWEEN DATEADD(day, -400, GETDATE()) AND GETDATE()
AND ra.RunbookId_21D8C930_42C9_63F5_5770_C67E9FEB1B2E = '9ADB0708-0EFC-43DB-B31B-71DB354216F0'
In this example I can capture a runbook under that guid. But I cannot see the one I need.
Thank you for any help! :)
Hi @Ryan_Kelley,
I think the WorkItem table in the ServiceManagement DB has a column called ParentWI which will be the top level parent, not just the direct parent. Would that help?
Geoff
That kinda helps but am looking how to get the runbooks under a PA. Would I join that table to itself to try to get all runbooks. Thank you!
