Portal SRs show wrong infomation after Portal upgrade from v6 to v7
Error in Adding WatchList User Ids
System.NullReferenceException: Object reference not set to an instance of an object.at Cireson.ServiceManager.Services.Implementations.RequestOfferingService.GetWatchListArray(RequestOfferingViewModel model)
Any idea? Please advise. Thank you.
During the upgrade, did you check the properties of the install file to see if it was blocked, and proceed to unblock it? Part of Windows Server causes portions of files to be blocked if it the source is detected that it was from another computer/downloaded.
The installer may have completed, however some files may have been blocked from being transferred/updated
Check the install file and see if it was blocked, if it was, you may attempt to reinstall the portal after unblocking the file.
The installation completed successfully. We saved the setuplog and I checked that log again, there is no error. Besides the issue doesn't happen on all the work items, only on a few WIs.
