DataWarehouse Cube Processing Errors and Issues
Hi Team,
We are having issues with Cube Processing within the service manager console. It hasn’t been working for a while and we created a PowerShell script to perform the tasks that the cubes were supposed to be doing and to have our data up to date.
We are trying to resolve this issue but it’s tricky, I was wondering if anyone has any ideas on this and can point me to the right direction.
The Cube obs are listed as failed and when I try and access
the cubes I get access is denied. Within SQL the access works with the same
username and password. All the user roles seem to be correct but I can’t access
the cubes within the console.
I have attached some screenshots if it makes it handy. Our SQL specialist isnt sure why it doesnt work as things from SQL end seem to be fine.
I'm not familiar with how all this connects together but i was wondering if anyone has experienced anything like this before and how they resolved it.
We want to retire the PowerShell script eventually and rely on the cubes to process the data correctly.
Any help will be appreciated.
Thank you.
Is there a firewall setup on the sql server by any chance? had issues with firewalls and ports used by analysis services before with similar errors. what does the operations manager log on the Service Manager datawarehouse server say?
Thank you.
so we repaired-installed visual c++ 2013 x86 and x64 were correct on all servers but it didn't work.
the service account is the one im using and its listed under the security section of the datawarehouse tab of the console.
using the service account, I can use excel to connect to the analysis server and load the cubes, I can also do that using my administrator account which has permissions to all cubes and databases.
now, we aren't getting a permission error after we repaired visual c++ but we are getting the below error which refers to the analysis server service how ever when I check the service its running, but on the event log on the dw server it comes up as crashed although it appears to be running.
could it also be a version issue on the console? I don't know what else to look at. confusing
so update on this,
the analysis server service had crashed on our second SQL server, turned it on and now we can access the cubes. How ever some are saying processed and some are saying partially processed. They are scheduled to run every 24 hours.
are there logs to this? is there any information on how this area works? im a little confused by it all and have no idea what to check and confirm if the cubes are running successfully.
any help on documentation or error logs/tracking on this will be much appreciated.
What we have noticed is that the Analysis Service on SQL keeps stopping every few hours, we have no idea why. we start it up again and it runs for a few hours then crashing, nothing else seems to be running to cause it to crash.
anyone have any insight on how this component work?
where will the msmdsrv.log file be on the SQL server, I have looked everywhere but cant find it. may be it it isn't turned on.
the event viewers just give the above errors, there isn't much else there.
a few warning messages are also appearing on the SQL server referring to
remote calls to SAM databse have been denied in the past 900 seconds throttling window.
otherwise I don't see anything else.
This is the default location i think \program files\Microsoft SQL Server\<instance>\Olap\Log.
