Prevent self select without using RO Toolbox
Does anyone know how to prevent a user selecting themselves from a AD user query result prompt?
Using portal version 9.6.0 on test environment and some of the RO toolbox functions are not working as discussed in other threads, so looking at using the default query result option.
Tried placing @PreventSelectSelf from the RO Toolbox before a default query result prompt but I can still pick my own user config item.
Peter_Miklian Customer Advanced IT Monkey ✭✭✭
@Priyan_Mistry with portal version 9.6.0 don't you think about using Request Offering Query Picker which is native to portal? I hope you can define filter on query using token which won't show current user.
5
