Help with Hardware Asset access.
We have two accounts with the same Asset Manager access. One can access a HW Asset, the other gets an error:
2016-06-30 09:42:30,690,Hardware Asset / Edit
System.NullReferenceException: Object reference not set to an instance of an object.
at Cireson.ServiceManager.Services.Implementations.HardwareAssetService.<GetEditViewModelDataAsync>d__27.MoveNext()
Same URL, different results. Any way to track down which object and what access is being withheld?
Thanks!!
Brian_Winter Customer Advanced IT Monkey ✭✭✭This turns out to be a known bug that is fixed in 5.0.8. We found that our Software Assets did not have a Asset Type which causes the HW Asset form to fail to load. Once SW Type (and Status) were populated, the error disappeared.6
Are both users able to access the hardware asset within the console? If so, let's make sure it's not a caching issue. Open a new browser, or use InPrivate/Incognito mode and try to access the asset. Same results?
Is the second user able to create a new hardware asset and immediately see/edit it?
