Does Archiver not respect scopes / queues?
Recently updated to 11.6.3, and we were excited for the new Archiver feature, which may signal the death of our DW.
But - does the Archiver not respect which WIs a given user is scoped to? Even on an active IR, the portal just opens the archived version instead of denying access - is this right, or have I messed to much with the code in the forbidden place? 🫣
Being a bit cheeky and tagging @Adam_Dzyacky 🤭
No worries 😁
The Archiver does respect Work Item scopes and it does so at the time of grooming. So if let's say three groups had access to that work item. Once it's groomed, those three groups would still have access.
But what you're describing about seeing an Active IR in an Archived state, could be a couple of different things that I've seen. Again, not saying this is definitively the answer, but just what I've seen in passing:
We've had a couple of bug fixes around the Archiver, but none that sound like what you're describing. If neither of the above items resonate, I'd encourage you to open a support case.
@Adam_Dzyacky we have a similar situation, where some End Users are not able to edit their Incidents, where they are the affected users.
They may open them but they are shown as archived. Right now I've only seen it with Resolved Status, but it might be the same with other status as well.
