Home Analyst Portal
Multi-Edit Options Not Working for CR/MA/RA
Chris_KeanderChris_Keander Customer Advanced IT Monkey ✭✭✭
I'm running v5.0.8.1 of the portal and just realized that I can't use the multi-edit buttons on the bottom window (Edit / Tasks) for CR, MA, or RA work items.
The Tasks are greyed out, and the Edit button is greyed out as well.  When you hover over it it says "Must select work items of the same type" even though I only have one work item selected
  • Joe_BurrowsJoe_Burrows Cireson Devops Super IT Monkey ✭✭✭✭✭
    Answer ✓
    Hey Chris
    That is because the bulk edit only supports SR and IR at this stage, id recommend putting through a feature request if you'd like to see other classes supported and which tasks you'd like it to have.
    Cheers
    Joe
This discussion has been closed.
