Enable paging feature for Query Result control
Problem:
we expected very long delays in loading data into the Query Result control.
For 4500-9000 datasets the time to load is between 10-20seconds.
If we enter any filter criteria while the control is in loading progress, the delay seems to be even longer(>1min)
Idea:
There should be a property "Paging" like it exists in Asp.net GridView control.
This will make the Query Result only load the displayed data and not all datasets.(speed up things!)
The possibility to filter while loading or after loaded the first page shouldn't be changed and should work normally.
This feature would really help to speed up the Cireson portal!
Thanks
Roger
