Has anyone been able to create a solution that allows a "multi-select" option within an enum list?
Is there a way to do this within the Cireson portal or is it a no-go given the SCSM limitations?
Billy_Wilson Member Ninja IT Monkey ✭✭✭✭
Its been my experience the preference is to use custom CIs in a Query Results question for multi-select (unless you own Cireson Asset Management, in which case, the CI for location already exists). I personally have done this for Locations and Projects (I worked for an O&G engineering company), both of which required multi-select.
Hope this helps.6
Hope this helps.
As Billy said, the a Query Prompt is the only way I've been able to achieve this. Unfortunately it's a bit of a beast and caused more confusion for our users.
I'm sure there's a feature request around here for a solution to this problem... I just can't find it.
@Adrian_Paech put together a nice customization here around improving the query result, + has a link to the feature request.
https://community.cireson.com/discussion/1167
