Review Activity, Notify Analyst Function Not Sending
I have a feeling that this may be something really simple, but I'm struggling to find what's wrong.
I'm starting to get to grips with Review Activities on Service Requests in Cireson. I've got the review activities set up and working. But I can't seem to get the "Notify Analyst" feature to send the emails out for RA's.
The Notify Analyst Function is working fine for the standard Incidents and Service Requests Notifications, but when allocating RA's it doesn't kick in.
Images below of how it's set up and a SR with RA that's not working.
Do I have to refresh anything to make them start working?
Thank you!
Brian_Wiest Customer Super IT Monkey ✭✭✭✭✭
Check your Management Packs installed there are two in relationship to this.
Both will have the same version. Sounds like it possible you got the Notify Analyst MP Pro installed but happen to have installed the workflows MP for the free addition.
And verify the Cireson.assigmenet.workflows.dll is in the SCSM directory that also the same version as the MP's5
To force a change to test that Skip the activity and then return.
Or return to the previous activity and complete it again.
Hi Brian & Billy, unfortunately neither worked, I had tried that earlier, but just tried again now and still no email.
It's weird as like I say it's fine for other types of notify analyst jobs.
We've now done those steps, but still no emails for the Review Activity. I'm sure it must be something I've not done quite right. I'm assuming the Notification "Targeted Class" should be review activity?
I think my only other option is to add a send email step to the runbook.
I wasn't aware of the Workflow status on Service Manager, found this:
I believe we do have the Pro version, as we have the RA sections etc. and the Licence shows in the licence app:
Any ideas on either how I confirm 100% that we have the Pro version, and if so, how I convince our instance of Cireson that we have it!
I'm thinking I may now need to contact Cireson support?
Next I would check SCSM workflows to see if they workflow is getting triggered
In workflow status admin verify they are enabled and check if there are any that need attention
Use this to determine your next step.
If working enabled logging in Notify analyst general settings
If not working review SCSM configuration/Notify settings. Could be the health state service or an issue with the mpsync jobs.
Yeh that's where I found the error above, it is triggering, but failing as it thinks we don't have Pro:
The error in all of them is as below:
System.ArgumentException: This workflow is disabled in the free edition of the Notify Analyst app. at Cireson.Assignment.Workflows.ReviewerNotification.Execute(ActivityExecutionContext executionContext) at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext) at System.Workflow.ComponentModel.ActivityExecutorOperation.Run(IWorkflowCoreRuntime workflowCoreRuntime) at System.Workflow.Runtime.Scheduler.Run()
They do show as Enabled:
