Post-Installation Problems
Just finished our SCSM Portal installation and I'm unable to launch the portal from the server, http://localhost. I'm getting a login dialog. Checking the setup log I see that I've configured it for Windows Installation so I don't think it's a Forms Authentication issue. The CiresonPortal site has Windows Authentication enabled, Forms Authentication disabled. The Cache Builder log shows errors with our AD groups. Our SCSM AD connector is configured for all users and groups. We do have the SCSM 2012 port installed on this box, wondering if that might be causing any issues.
Banging my head on the wall over this one.
Best Answers
Would need more information to help with the issue. Like what the exact errors are. A possible screen shot. I would suggest reading through the series of articles we have on Portal deployment and verifying you have all perquisites in place before attempting the installation again
https://community.cireson.com/discussion/47/walk-through-portal-deployment-example-part-1
https://community.cireson.com/discussion/680/walk-through-portal-deployment-example-part-2
Let me know if you have further questions,
Merle5
Merle
Thanks for the links, I don't have an errors when trying to access the portal page, just a login prompt and then access denied.
I'm going to reinstall the portal and see if that gets me started. I'll open another support case if I still have issues.
During the new install, I'm having a problem getting the App Pool Identity password to verify. I can't get rid of the yellow triangle. I've tried several AD accounts and they all fail. The message is "The password appears to be incorrect. Exception: The server cannot handle directory requests."
I'm logged in with my domain account. I forged ahead with the install anyway and it did finish successfully. When I clicked on the link to the portal, http://localhost, all I get is the default IIS page.
Sounds like you have the default website with a conflicting binding to the ciresonportal (meaning ciresonportal is in a stopped state in IIS right now).
Id recommend changing the binding of the default IIS website or deleting it. Then start the CiresonPortal.
Hello Joe,
From what I can see, the default website is stopped, I think the Cireson setup did that. I can remove it I guess.
I'm in the process of uninstalling it right now. If you can give me a few minutes so I don't waste your time, I'll have things ready to start again....
I'm at 714-347-8775
I'm at 714-347-8775
Running as the Cache Builder Service account got rid of the yellow triangles. Just got a message "Almost done!" Please restart your server and run the setup again.
Restarting....
Thanks. Nothing ever looked so good. Appreciate the help in finding my Cache Builder account 'missing' in SCSM and figuring out that installing it under the Cache Builder service account worked better.
