Best practices for updating Catalog Items and Hardware Assets
In the Asset Management Settings, is there a best practice for the workflow settings (I'm using SCCM) ? For example, should I need to run the HW Asset workflow before the Catalog Item workflow or vice-versa ? What are best practices for the other options available in the Cireson Asset Management settings ?
Hopefully we've covered this one off elsewhere but in case you still unsure or someone else finds it
I would run the HWA Sync first, allow for it to completely finish (you will need to monitor the average time it takes from the logs) and then let the Catalog Item workflow run.
And before the HWA sync runs, ensure the ConfigMgr connector has fully finished (again look and how long it takes) to avoid a longer delay between new items being discovered by ConfigMgr and being created as HWAs.
Geoff
https://community.cireson.com/discussion/comment/11905#Comment_11905
