"Assign Analyst By Group" for (Manual) Activities
is there a way to activate the "Assign Analyst By Group" feature for manual activities? When I click on the button I always get the error message: "The task has not been configured for this class." (see attachement)
Thank you very much!
Brian_Wiest Customer Super IT Monkey ✭✭✭✭✭
You need to add support groups to your MAHere is the content to do so.
1
You need make sure that the after it is installed you a) verify that it is licensed in Administration > Settings > Cireson - Console App Licensing and b) Configured for manual activities in Administration > Settings > Cireson - GroupAssign Settings.
thank you for your response. The app is licensed but I don´t find any configurations for manual activities within the "GroupAssign Settings" (see attachement).
One more question: Now I have two Support Group fields within the Web Portal (see attachement). The good part is that no matter what field I use, both fields are affected.
Do you have an idea where I can delete the yellow one? Because the red one is from your java script content.
MA2SGF_AddSelectBox(data, id, selected)
Now I only have one Support Group field to choose from.
