Portal - Multiple Versions Same DB?
Curious to see how many / if people run Multiple Versions of Cireson Portal using the same database. Either in a single server or multiple servers running different versions while using the same db.
Such as running v5.0 Hotfix 10 and v6.0 Official.
I have done this from time to time in a Lab environment and a 'pre' production environment. Checking to see how common this is within the community.
I've always ended up having to do two separate DBs, to get two separate portal versions, but still point them at the same SCSM CMDB backend (or copies of SCSM on a different DB with regular restores/refreshes to a dev SCSM instance) in order to achieve said pre-production environment.
I usually see these deployed across separate DB's. Not to say that it wont work you just may run into issues with the differing versions of website files and DB SPs.
