System.WorkItemRequestedByUser = Requested By in Incident.js and/or ServiceRequest.js
Dear community,
I've a form topic with the "RequestedByUser" relation. It has the same TargetName as "CreatedByUser"...
So it isnt' possible to use the PropertyName entry for ServiceRequest.js to display that information.
Is there a way to give more or different properties in .js to display Requested By info?
E.g. source or any of the ID's instead of the TargetName in table ServiceManager.RelationshipType
{ DataType: "UserPicker", PropertyDisplayName: "RequestedBy", PropertyName: "CreatedWorkItem"}
Thanks in advance for your replies! ;)
Best Answers
Shane_White Cireson Support Super IT Monkey ✭✭✭✭✭
Hi Peter,
I have uploaded a community solution here:
Thanks,
Shane 😊
5 -
Peter_Muttenthaler Partner Advanced IT Monkey ✭✭✭
Hi Shane,
thank you for quick reply!!
Your solution is working great for me :).
BR
Peter
0
Hi Peter,
Unfortunately you cannot have Requested by and Created by on the same form due to those target names being the same. This is a Microsoft issue for naming those targets the same so this is not a supported scenario I am afraid. You could however do a display only field using Javascript to pull this information in and just display it.
Thanks,
Shane
Hi Shane,
Thank you for your reply! ;)
Do you already have some code to put it to custom.js?
Display only is enough for me ;).
Thanks in Advance!
Best regards,
Peter
Is there a way to use any other information out of that table instead of the bad targetname?
e.g. (which is not working):
{ DataType: "UserPicker", PropertyDisplayName: "RequestedBy", PropertyName: "RelationshipTypeID:F6205E94-82F9-9A97-3B4F-C7127AFB43A8"}
I've same trouble with pageForm.viewModel information's. Even there the correct user for IsRequestedByUser isn't displayed correctly... :(
Hi Peter,
I am looking into a custom solution, please bare with me 😊
Thanks,
Shane
Hi Shane,
great thank you! :)
Hi Peter,
Thanks,
Shane 😊
Hi Shane,
BR
Peter
